| PCV VALVE REQUIREMENTS FOR SUPERCHARGED SLANT 6 https://slantsix.org/forum/viewtopic.php?t=63902 |
| Author: | BUCKET 636 [ Mon Aug 05, 2019 9:46 pm ] |
| Post subject: | PCV VALVE REQUIREMENTS FOR SUPERCHARGED SLANT 6 |
Hope this is the right section. As the title says what would my requirements be for crankcase ventilation on a supercharged slant 6 ? SC is a L67 Eaton with aa a draw through set up Weber 45 DCOE. I will post a photo of my current PCV valve and line tonight > I have heard about second circuits and catch cans , I am only running around 7 -8 PSI. Cheers, Greg |
| Author: | BUCKET 636 [ Tue Aug 06, 2019 2:14 am ] |
| Post subject: | Re: PCV VALVE REQUIREMENTS FOR SUPERCHARGED SLANT 6 |
The reason i am asking these questions is my PCV Valve line connects to the SC neck/elbow just before where the SC bypass valve is . As i don't know much about vacuum i was wondering if when the bypass valve is open which is most of the time would there be turbulence which would affect the way the PCV valve operates ? https://live.staticflickr.com/65535/484 ... 92ce_m.jpg https://live.staticflickr.com/65535/484 ... 74ee_m.jpg https://live.staticflickr.com/65535/484 ... e3b3_m.jpg https://live.staticflickr.com/65535/484 ... 250a_m.jpg https://live.staticflickr.com/65535/484 ... 1218_m.jpg |
| Author: | emsvitil [ Tue Aug 06, 2019 3:53 am ] |
I don't know the answer (yet??) Try bigger pictures so I can see what's going on. |
| Author: | kesteb [ Tue Aug 06, 2019 8:22 am ] |
That should work. How are you protecting the Teflon coating on the rotors? |
| Author: | BUCKET 636 [ Tue Aug 06, 2019 12:50 pm ] |
Quote: That should work. How are you protecting the Teflon coating on the rotors?
I removed the coating before i put the SC on as it was crappy .I realise i will be loosing some PSI by doing this . I am currently in the process of getting another set of rotors re coated by a business in Brisbane . The coating they use can handle petrol and air . |
| Author: | BUCKET 636 [ Tue Aug 06, 2019 1:09 pm ] |
Quote: I don't know the answer (yet??)
Can't figure that out , Flickr is only saving them as thumbnails .
| Author: | BUCKET 636 [ Wed Aug 07, 2019 1:50 am ] |
https://www.flickr.com/photos/183261515 ... ed-public/ |
| Author: | BUCKET 636 [ Wed Aug 07, 2019 1:55 am ] |
https://www.flickr.com/photos/183261515 ... ed-public/ https://www.flickr.com/photos/183261515 ... ed-public/ https://www.flickr.com/photos/183261515 ... ed-public/ https://www.flickr.com/photos/183261515 ... ed-public/ |
