| Help with spark plugs...for my 225 https://slantsix.org/forum/viewtopic.php?t=63916 |
| Author: | beto_valiant64 [ Fri Aug 09, 2019 9:46 pm ] |
| Post subject: | Help with spark plugs...for my 225 |
Help, i have a 1964 Valiant 225 3.7L and i cant find spark plugs with a 5/8" hex on it, everywhere i go they have the 13/16" hex, can somebody please tell me the brand and number (spark plug i can use) thank you... the 13/16" hex are too big, socket didnt even fit.... |
| Author: | SlantSixDan [ Fri Aug 09, 2019 10:08 pm ] |
| Post subject: | Re: Help with spark plugs...for my 225 |
The original plugs used a 13/16" hex (you would need the correct socket for them). The best plugs to use, though, do have the smaller 5/8" hex. They're this one, the NGK ZFR5N (stock number 3459). Remove the metal ring washer from each plug before installing it; the ring washers are not used on '63-'74 Slant-6s. Find more tune-up parts and technique suggestions in this post. |
| Author: | Dart270 [ Sat Aug 10, 2019 5:08 am ] |
Make sure of the year engine you have. Does it have the aluminum spark plug tube inserts? If so, then Dan is right and 13/16" is stock but some aftermarket plugs use 5/8". Make sure to get the right plugs for your engine as there are two totally different types. Lou |
| Author: | GTS225 [ Sat Aug 10, 2019 6:31 am ] |
Quote: Make sure of the year engine you have. Does it have the aluminum spark plug tube inserts? If so, then Dan is right and 13/16" is stock but some aftermarket plugs use 5/8". Make sure to get the right plugs for your engine as there are two totally different types.
***************************************************************************************Lou To be more technically correct, make sure of the year of the head that's on your engine. It could have been replaced at some time in the past with a later year head, perhaps in order to "fix" a bad valve problem. Roger |
| Author: | beto_valiant64 [ Sat Aug 10, 2019 9:48 am ] |
Quote: The original plugs used a 13/16" hex (you would need the correct socket for them). The best plugs to use, though, do have the smaller 5/8" hex. They're this one, the NGK ZFR5N (stock number 3459). Remove the metal ring washer from each plug before installing it; the ring washers are not used on '63-'74 Slant-6s. Find more tune-up parts and technique suggestions in this post.
thank you... |
