| cleaning connections at bulkhead connector https://slantsix.org/forum/viewtopic.php?t=63926 |
| Author: | Charrlie_S [ Mon Aug 12, 2019 6:05 am ] |
| Post subject: | cleaning connections at bulkhead connector |
I think I found a good way to clean the terminals in the bulkhead connector. Don't know if it will be OK long term, or on heavily corroded terminals. I unplugged the connector, and removed from the firewall. Then put white vinegar in a freezer bag, submerged the connector in the vinegar and put a rubber band around the bag/wires, and let it soak for awhile. Dumped the vinegar and replaced it with water, then rinsed with a baking soda solution in the bag to neutralize the acids. Dried with air pressure, and hair drier. Then coated the connectors with dielectric grease prior to plugging back together. |
| Author: | jcc [ Mon Aug 12, 2019 6:57 am ] |
| Post subject: | Re: cleaning connections at bulkhead connector |
You didn't mention you did it, which you might have, but I would have included at least one post baking soda wash with at least one pure water wash, and I think the dicelectric grease is probably the most underrated preventive solution for this connection. |
| Author: | Charrlie_S [ Mon Aug 12, 2019 12:53 pm ] |
Quote: You didn't mention you did it, which you might have, but I would have included at least one post baking soda wash with at least one pure water wash, and I think the dicelectric grease is probably the most underrated preventive solution for this connection.
Didn't mention it, but yes, I did a pure water wash after the backing soda bath
