water pump housing on block
https://slantsix.org/forum/viewtopic.php?t=63933
Author:  Thebearded1 [ Mon Aug 12, 2019 3:57 pm ]
Post subject:  water pump housing on block
I'm in the process of cleaning out the block (225) and replacing the water pump and noticed this cavity in the block (pointing the screw driver at it) is this a water passage filled with crud or just part of the casting? I see that its not connected with the impeller area or passage below but just wanted to double check. I didn't see this on another photo of a slant block. I think the block is a 68 or 69
Author:  Doctor Dodge [ Wed Aug 14, 2019 8:28 am ]
Post subject:  Re: water pump housing on block
Normal and found on many SL6 blocks.
The correct water pump gasket seals-off that "cored-out" area, to prevent crud build-up but a bead of sealer will also do the job.
Author:  Thebearded1 [ Wed Aug 14, 2019 10:11 am ]
Thanks DD! This is m first slant but its been a lot of fun learning about these motors on this site.
