What Coolant Sensor To Use for '85 head on '68 block?
https://slantsix.org/forum/viewtopic.php?t=63958
Page 1 of 1
Author:  csheehy [ Fri Aug 16, 2019 7:53 pm ]
Post subject:  What Coolant Sensor To Use for '85 head on '68 block?
I'm (temporarily) running a 1985 peanut head cylinder head on a 1968 barracuda. The coolant temperature sensor is much larger on the '85 head then it is on the '68. Does anyone know what part number I need for the correct temperature sensor that will work with the '68 Rallye gauges (non idiot light)? This could be a very obvious question, but I'm stumped.
-Chris
Author:  SlantSixDan [ Fri Aug 16, 2019 8:37 pm ]
Post subject:  Re: What Coolant Sensor To Use for '85 head on '68 block?
Try this sender with this connector (yellow wire should go to your existing temp sender wire, black to ground).
Author:  csheehy [ Sat Aug 17, 2019 6:58 am ]
I'll go that route if I have to Dan (TY for the quick reply!!!), but am hoping to find one that will appear more OE for the application - perhaps a one-wire solution.
Author:  Badvert65 [ Sat Aug 17, 2019 9:09 am ]
Why not use a brass adapter and the 68 sender. Or, just plug the big hole and tap a new one for the 68 sender.
Author:  csheehy [ Sat Aug 17, 2019 11:50 am ]
Great idea @badvert65 would you have a part number or link for that?
Author:  Killer6 [ Sat Aug 17, 2019 1:42 pm ]
You need a pipe thread bushing, I'll be honest, don't recall what size they are, but maybe 1/4-1/8 NPT reducing bushing......whatever, they are not an uncommon item............
Author:  Rick Covalt [ Sat Aug 17, 2019 4:30 pm ]
Hardware store item.
Author:  kesteb [ Sat Aug 17, 2019 7:00 pm ]
Your '68 sensor can go in the npt threaded hole above #1 exhaust port. The 2 larger npt threaded holes next to the thermometer can be blocked.
Author:  csheehy [ Sun Aug 18, 2019 3:28 pm ]
@badvert65, the bushing idea was genius, I certainly wasn't seeing the forest through the trees. So as to help the next person who runs into this situation - the brass reducer bushing size that works is 3/8" M X 1/8" F, and was as close as my Ace Hardware Store for cheap. Thanks to all! -Chris
@kesteb, the thread pitch isn't a match, couldn't do that.
Author:  kesteb [ Mon Aug 19, 2019 6:56 pm ]
Funny, a 1/8-27 NPT tap works in that hole for every head that I have. So I don't see why yours would be different. But I am glad that you found a solution.
Author:  slantzilla [ Mon Aug 19, 2019 10:10 pm ]
IIRC, I ran into the thread pitch thing on one of my heads, and it was straight thread, not pipe.
