where can i get a small crank flange(62-67) flywheel?
https://slantsix.org/forum/viewtopic.php?t=63980
Page 1 of 1
Author:  upnover [ Thu Aug 22, 2019 3:08 pm ]
Post subject:  where can i get a small crank flange(62-67) flywheel?
where can i get a small crank flange flywheel? i have an older /6 engine (1962) and a late flywheel(1968 and newer), the register on the crank is 1.96" and the flywheel that i have and the one that is available is the larger 2.16". brewers has the larger but i cant find a small one, there isent an adapter ring available is there? thanks guys! i am using the small clutch
Author:  Fopar [ Thu Aug 22, 2019 4:07 pm ]
Post subject:  Re: where can i get a small crank flange(62-67) flywheel?
I have a clutch and flywheel from my 63. Where are you located?
You can have them for shipping.
Richard
Author:  upnover [ Thu Aug 22, 2019 5:56 pm ]
im in tulsa, ok 74107. business address, thx
Author:  Fopar [ Fri Aug 23, 2019 6:25 pm ]
Check your private messages.
Richard
