Balancer trouble?
https://slantsix.org/forum/viewtopic.php?t=6402
Author:  oldsubguy [ Tue Jul 29, 2003 7:56 pm ]
Post subject:  Balancer trouble?
1977 aspen 225/6. When at idle it vibrates quite a bit. Does not idle rough but resonates/vibrates. how do I tell if the harmonic balancer is bad? Can they go bad?
Author:  Pierre [ Tue Jul 29, 2003 9:16 pm ]
Check torque converter bolts to make sure they aren't loose.
Author:  Volaredon [ Wed Jul 30, 2003 7:35 pm ]
Post subject:  vibration
Momentarily disconnect the belts, 1 at a time, start the engine and see if it goes away. Could be bad alt. or WP bearings. Just had a bad WP a month ago on a friend's 78 Volare wagon. Solid O.E. fan w/spacer, fan was missing 1-1/2 of its 5 blades. (Ended up costing me a trip to the ER and 9 stitches on the back of my left hand from the busted, and sharp fan!)
