It is currently Wed Nov 18, 2026 12:38 am
 Post subject: Oil Pressure gauge
PostPosted: Thu Feb 18, 2021 10:34 pm
Car Model: 1965 Dodge A100 Pickup w/Super Six
Have had my '65 A100 for six years and the oil pressure gauge has always read 0. The 225 ran well so I wasn't worried (and there was plenty of things to fix). When I checked behind the gauge there was no line to the engine. The slant was from '76 and I just put a '65 engine into the truck which has a port tapped in passenger side. I have the appropriate oil line installed now and am about ready to fire up. Do I have to bleed the line for it to work properly? Thanks
Gary
 Post subject: Re: Oil Pressure gauge
PostPosted: Thu Feb 18, 2021 11:48 pm
I can't imagine why you'd need to bleed the line. I certainly never have. (I'm assuming you're talking about a mechanical gauge, that has a tube going all the way from source to destination.) Unlike other hydraulic control systems where air pockets are problematic, this is merely measuring pressure. Any air pockets will be squeezed by whatever pressure is presented, in which case they'll change in size slightly but I'll bet that effect is too small to notice... Long story short, regardless of the compressibility of any portion of the contents, there's nothing that would prevent pressure inside the tube from telegraphing all the way to the gauge.
- Erik
PostPosted: Fri Feb 19, 2021 7:55 am
Thanks Fanatic. First time in the category for me, and I was unsure how it worked. G
PostPosted: Fri Feb 19, 2021 8:12 am
I have always bled my Mechanical Oil Pressure gauges Lines.
I thought if I bleed the brakes, and the coolant system then why not this too.
It's easy to do. I have never tested to see what if any error comes from having a `3foot line filled with air vs. one that was bled.
PostPosted: Fri Feb 19, 2021 9:38 am
The brakes matter because a bubble of compressible substance reduces total fluid movement.
The coolant matters because a bubble gets in the way of heat transfer.
There's nothing wrong with bleeding air bubbles in a pressure tester if you want to... but in this unique case, the volume (or volume change) inside the tube is irrelevant. As long as whatever substance in the tube is free to move (e.g. not blocking the tube), you can put ~50psi into one end of a tube and you get the same pressure out the other end, you've achieved your goal.
The original poster's question is understandable. I cannot think of any other system where having a mixture of stuff (compressible vs non-compressible) offers no detriment.
- Erik
PostPosted: Fri Feb 19, 2021 6:48 pm
I think the air in the line eventually disappears............
Not by leaking, but by being absorbed into the oil slowly.
Users browsing this forum: Google [Bot] and 7 guests
