| Rear Brake Line Tee Fitting for 8-3/4" https://slantsix.org/forum/viewtopic.php?t=64133 |
| Author: | SpaceFrank [ Mon Oct 14, 2019 3:40 pm ] |
| Post subject: | Rear Brake Line Tee Fitting for 8-3/4" |
Does anyone have a part number for the rear axle brake line tee fitting for an 8-3/4"? I'm having trouble turning up anything relevant with my searches. My 8-3/4" axle housing didn't come with hard brake lines or the driver's side tee fitting installed. The threaded hole for the fitting is there; fine thread, maybe 3/8". For reference, the later 8-1/4" that's in the car right now has a combination tee fitting with a bolt that also serves as an axle vent. I want to say my old 7-1/4" was the same way, but I'm not sure. |
| Author: | DusterIdiot [ Mon Oct 14, 2019 6:31 pm ] |
| Post subject: | Re: Rear Brake Line Tee Fitting for 8-3/4" |
Quote: the later 8-1/4" that's in the car right now has a combination tee fitting
Ummm... on the late cars, the "tee" is part of the rear axle brake hose assembly ($15-23 part)...especially on the A-body 8 1/4"...similar to Raybestos BH36648... the hard lines can also be gotten from one of the vendors that sells brake line kits. The vent bolt on a late 8 1/4" is kind of over kill as they have a tube that comes out the housing and goes to a flared out opening on one side of the housing or the other... Good Luck... |
| Author: | SpaceFrank [ Mon Oct 14, 2019 7:37 pm ] |
Ah, I see. The fitting on the car right now is so caked in grime I couldn't tell the tee was part of the hose. I guess it's been a few years since I did this rear axle conversion... I just need to make sure I order the right length rear line, then. The missing vent bolt is available at Dr. Diff and plenty of other places. Thanks! |
