1988 Dodge Ramcharger 4 speed manual to slant six
https://slantsix.org/forum/viewtopic.php?t=64142
Page 1 of 1
Author:  Pgbarrow [ Thu Oct 17, 2019 1:39 pm ]
Post subject:  1988 Dodge Ramcharger 4 speed manual to slant six
Would anyone know if a four speed off of a 1988 Dodge Ramcharger would fit onto a 73-74 slant 6? I have the old 3 speed auto with bell housing if that helps at all.
Paul
Author:  Joshie225 [ Thu Oct 17, 2019 2:42 pm ]
Post subject:  Re: 1988 Dodge Ramcharger 4 speed manual to slant six
The 1988 Ramcharger is a V8 so the bellhousing won't bolt to the slant six. The transmission itself may or may not be useful. If you're after the A833OD you can ID it by the shifter being externally mounted on the left side of the gearbox. Also, the A904 automatic has an integral, non removable bellhousing so it's of no help.
Author:  Greg Ondayko [ Thu Oct 17, 2019 4:06 pm ]
Get a pic.
I have never seen the od in the 81-93 'chargers or traildusters.
The ones i have seen were the big np four speeds.
But I am no expert on all things ramcharger. I only have 1.
Author:  Pgbarrow [ Fri Oct 18, 2019 9:43 am ]
Thanks again for the info Josh,
And rats to the auto bell housing being non-removable. I haven't been able to tell due to the grease. The yard that vehicle is in is too far for me to go if I am not certain. Will keep looking.
Paul
