early a-body rear end width?
https://slantsix.org/forum/viewtopic.php?t=64149
Author:  blown340 [ Sun Oct 20, 2019 9:27 am ]
Post subject:  early a-body rear end width?
Hi All, is the early A-body axle width the same as that on the later 67+ A-bodies? Put another way, will the 8.75 I have from a 71 valiant fit without modification into my 1963 which currently has the original 7.25" axle?
Thanks,
-Jon
Author:  slantzilla [ Sun Oct 20, 2019 10:37 am ]
Post subject:  Re: early a-body rear end width?
Yes. You will need to use the u-bolts and shock plates that go with the 8-3/4. You will also need to shorten the driveshaft about 1-3/4".
Author:  Dart270 [ Sun Oct 20, 2019 6:03 pm ]
Dennis is spot on...
Author:  blown340 [ Sun Oct 20, 2019 9:50 pm ]
Thanks Dennis and Lou, looks like what I have will work. Fortunately I have the shock plates, u-bolts, etc.. Time to get to work!
-Jon
