It is currently Fri Nov 27, 2026 7:24 am
PostPosted: Mon Aug 04, 2003 3:56 pm
Anyone know exactly (precisely, as in engineering drawing precise) what the angle of the slant six is? That is, what angle is the head surface at in relationship to a horizontal line?
Andy
PostPosted: Mon Aug 04, 2003 4:08 pm
...my references say it's 30 deg. from vertical. Sound about right?
"DW"
If it ain't broke, fix it!
PostPosted: Mon Aug 04, 2003 4:10 pm
30 degrees from vertical is the number I remembered as well :) That is for the block centerline -- Head surface would be 30* from horizontal (assuming the head surface is perfectly perpendicular to the block CL)
-S/6
PostPosted: Mon Aug 04, 2003 7:35 pm
Everything I have ever read about the Slant Six is that the cylinder axes are 30 degrees from vertical. :o
PostPosted: Tue Aug 05, 2003 10:02 am
Thanks everyone. I'll double check the angle when I get it all mocked up and see where we're at.
