| Do I have a bent push rod? https://slantsix.org/forum/viewtopic.php?t=64167 |
| Author: | tattoosteve99 [ Mon Oct 28, 2019 11:31 am ] |
| Post subject: | Do I have a bent push rod? |
Finally got her up and running. Tapping valves lead me to do a adjustment (needed it anyway). Short story. When I adjust them they don’t stay in tolerance. Engine is warm. I set them and then it changes either looser or tighter. Is this a bent pushrod or something else? Oh and thanks Dan for the HEI write up and heavy duty charging system upgrade!! |
| Author: | GregCon [ Mon Oct 28, 2019 1:10 pm ] |
| Post subject: | Re: Do I have a bent push rod? |
Doubtful but your adjusting screw threads could be too loose. It's odd for them to tighten, though. |
| Author: | SlantSixDan [ Mon Oct 28, 2019 4:36 pm ] |
Info on how to deal with loose adjustors that won't hold an adjustment is in the valve adjustment article. |
| Author: | tattoosteve99 [ Tue Oct 29, 2019 12:05 pm ] |
Quote: Info on how to deal with loose adjustors that won't hold an adjustment is in the valve adjustment article.
Thanks Dan! Got it done. Runs a little rough still but it has been setting for 7 months :/
