It is currently Mon Jul 06, 2026 1:26 pm
PostPosted: Thu Oct 31, 2019 5:58 pm
Car Model: 1962 and 1965 Plymouth Valiants
Hello my /6 brethren, hope ya'all had a good summer wiith lots of /6 adventures. I've finally got to work on mine again (a year later). A question: Where is the best place to store an engine in a crowded garage? Answer:In an engine bay of your car that been sitting empty for 35 years. The engine is a donor, model year 1968 225 ci, going into my 1962 Valiant. (Another ?) do I need to change the oil pan. It appears that the front of the sump will not clear the k member, by a couple of inches. Does that sound about right? (oh yeah another ?)
I can't get it all the way back to the firewall due to the LA explosion proof bellhousing hitting the floor tunnel. I am cutting that out, hopefully tomorrow, but was hoping to get a head start on finding an oil pan if I need to change it. (Another ?) anybody got a 1962 oil pan they can get rid of? Guess I need pick up tube as well!!!!!!!!
Thanks for any help you can offer
Kevan
PostPosted: Fri Nov 01, 2019 3:54 am
Yes you will need a different pan for that chassis.
PostPosted: Fri Nov 01, 2019 11:06 pm
An Aspen/Volare pan will also almost fit. A little hammer work in the front left corner and maybe under the drag link in back.
PostPosted: Sat Nov 02, 2019 11:28 am
they had all those different pans for a 60-66 A body?
PostPosted: Sat Nov 02, 2019 1:44 pm
No. Just the top left one in Mr. Dutra's picture.
Aspen volare pans are easier to find.
PostPosted: Sat Nov 02, 2019 3:29 pm
Kevan
You will also need the pick up tube and no one makes them any more so you will need to find a used one and clean it up.
Brian
63 Plymouth Valiant Wagon
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
