It is currently Fri Nov 27, 2026 2:29 am
PostPosted: Sat Jul 26, 2003 2:39 am
Ok, I have read up on what you guys said to do, and I have two new problems. One, where do I get a Pertronix Conversion for my slant 6 225? The second is, where do I get a 4 bbl carb that I can change for my stock carb? Websites would be great. Thank you guys so much for your help!
John, slant 6 225
PostPosted: Sat Jul 26, 2003 2:53 am
John, unless you plan on doing a bunch of other modifications (i.e. cam, exhaust work at the very least), I'd recommend you don't get any more drastic than a 2bbl factory super six setup. You can bolt a four barrel on your otherwise stock engine, but I betcha it'll run like crap. Check out the great info in the articles section (yeah, it took me a while to notice they were here, too :wink: ) Pay particular attention to the super six bit.
"DW"
P. S. - You must be a real masochist wanting to do that manifold job again so soon!
If it ain't broke, fix it!
 Post subject: ok thanks
PostPosted: Sat Jul 26, 2003 12:03 pm
dw,
Haha, Thanks, You see it is this kinda stuff I need to learn. Although I already replaced most of the exhaust. Thanks for the advice.
John slant 6 225
PostPosted: Sat Jul 26, 2003 4:21 pm
John, might I suggest, you register on the site, and log in. That way you will not show up as "guest".
 Post subject: Sources
PostPosted: Mon Jul 28, 2003 5:07 pm
A lot of the mail-order places carry the Pertronix. Summit and J.C. Whitney come to mind. Your local speed shop could probably also order one for you.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: Our friends at Ebay
PostPosted: Fri Aug 01, 2003 8:33 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
I was able to score a Pertronix Stage I and a hi-po coil from a guy on Ebay for less than $100. There's a shop that sells Petronix and even if they aren't posting any for the /6 they can order it for you. Sorry I forget the name.
Good luck,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Fri Aug 01, 2003 2:36 pm
On the note of running a 4 barrel on a stock engine - I tried running a holley 8007 (390cfm vacuum secondaries) on my motor (stock, other then clifford manifold and dual shorty headers with single 2 1/4" pipe to the back). Out of the box, I couldn't get it to run right. I spent a bit of time fiddling, but to no avail. My next step was to tear into it and replace the jets etc to what was recommended, but I decided to take a different route all together.
