| Microsquirt https://slantsix.org/forum/viewtopic.php?t=64253 |
Page 1 of 2 |
| Author: | Reed [ Mon Nov 25, 2019 7:59 pm ] |
| Post subject: | Microsquirt |
I have read that the microsquirt will trigger off of an HEI ignition system. Can anyone confirm this? Is it triggering off the 7 pin HEI module or the four pin? |
| Author: | MadScientistMatt [ Tue Nov 26, 2019 5:18 am ] |
| Post subject: | Re: Microsquirt |
Yes. A 4 pin HEI would have the MicroSquirt controlling just fuel, triggered off the coil, like this: http://www.msextra.com/doc/pdf/html/Mic ... .4-76.html A 7 pin HEI paired with a locked distributor (like a Lean Burn - that's what I'm using) would let the MicroSquirt control timing. There's a wiring diagram for these modules here: http://www.msextra.com/doc/pdf/html/Mic ... .4-85.html |
| Author: | Greg Ondayko [ Tue Nov 26, 2019 8:19 am ] |
What is the total Cell Map availability for Micro squirt? 8X8? 12X16? I was just thinking about a microsquirt vs msIII for a next installation. Greg |
| Author: | Reed [ Tue Nov 26, 2019 9:05 am ] |
16 x 16 fuel and spark tables https://www.diyautotune.com/product/mic ... -ecu-only/ |
| Author: | Dart270 [ Tue Nov 26, 2019 1:31 pm ] |
Yeah, this has got me thinking too. I don't want to put a crank trigger on my new supercharger motor (pulley/space), so maybe microsquirt is the way to go. Lou |
| Author: | Reed [ Tue Nov 26, 2019 3:19 pm ] |
I have been thinking of the cleanest, cheapest, and easiest EFI installation and I keep coming up with microsquirt. I am thinking HEI triggering the Microsquirt with two batch-fired injector banks (or maybe TBI) and wasted spark. A 16x16 spark/fuel table shouldn't be too much tuning to deal with. Self-learning would be nice, but you get what you pay for. I have enough hardware to do two SEFI MAF systems based on Ford components, but I have three vehicles I am thinking about injecting. |
| Author: | emsvitil [ Tue Nov 26, 2019 4:15 pm ] |
I believe there's 2 different operating systems (firmware) that run on the microsquirts from two different companies. Make sure you pick the one that does what you want |
| Author: | DadTruck [ Tue Nov 26, 2019 5:08 pm ] |
Quote: microsquirt will trigger off of an HEI ignition system.
used a seven pin HEI with a locked Lean Burn distributor When I ran the 68 Barracuda at the strip, I would get intermittent spark plug mis fires at high load and high RPM,, I am sure the engine I was running did not have the best piston ring sealing and I am sure that my fuel tune was not the best. I swapped the ignition over to a MSD box,, with no changes to the engine or the fuel tune and the mis fires went 100% away. Still using the Lean Burn distributor. Not saying that the HEI is not a good ignition, but on my car the MSD gave vastly superior results. I buy my MS stuff through DIYAutotune, I have got great support from them. There is also an online support forum http://www.msextra.com/forum-info/ |
| Author: | Greg Ondayko [ Wed Nov 27, 2019 4:29 am ] |
So John in your situation you use the Lean burn locked to trigger the MSD Box which now sends signal to Your microsquirt / megasquirt etc...? Greg |
| Author: | DadTruck [ Wed Nov 27, 2019 6:14 am ] |
Quote: locked to trigger the MSD Box which now sends signal to Your microsquirt / megasquirt
actually the two wires on the lean burn distributor both go to the MegaSquirt ECU, there is a wire that connects the ECU to the MSD box that triggers the MSD to fire. The wiring is really simple. To allow the spark to happen at the exact correct moment, there is a 'timing wizzard' within the MS set up process that assists one to set the actual locked ignition timing within a specific window. Once that is done, working from that known setting the MS ECU adjusts the firing of the ignition to occur (fire the MSD box per your desired timing curve) as you have inputted. That is my 'garage mechanic' interpretation of what happens. |
| Author: | Joshie225 [ Wed Nov 27, 2019 7:26 am ] |
Quote: Quote: microsquirt will trigger off of an HEI ignition system.
used a seven pin HEI with a locked Lean Burn distributorWhen I ran the 68 Barracuda at the strip, I would get intermittent spark plug mis fires at high load and high RPM,, I am sure the engine I was running did not have the best piston ring sealing and I am sure that my fuel tune was not the best. I swapped the ignition over to a MSD box,, with no changes to the engine or the fuel tune and the mis fires went 100% away. Still using the Lean Burn distributor. Not saying that the HEI is not a good ignition, but on my car the MSD gave vastly superior results. |
| Author: | Greg Ondayko [ Wed Nov 27, 2019 8:21 am ] |
I too have had bad 4 pin gm modules on non efi cars.. I went back to chrysler electronic ign box from hei conversion as I was getting tons of misfires and it broke down with the family and had to get towed. What are the good hei 4 pin modules? MSD or others? Thanks for clairifing john.. that makes sense. Timing input control to mS and then its map controls msd which fires your coil. Greg |
| Author: | Joshie225 [ Wed Nov 27, 2019 12:12 pm ] |
I've been fortunate enough to find good used GM modules in self-serve wrecking yards when I've needed them. The MSD replacement was supposed to be a good one in years past. The reviews at Summit Racing are mixed with 12(!) one-star ratings. I'd probably skip it as it's an expensive part at $110 even if it does have rev limiting. The Davis Unified Ignition module has good reviews, all 4 or 5 stars and costs $49.50. |
| Author: | Greg Ondayko [ Wed Nov 27, 2019 1:27 pm ] |
At this point I would definently trust the d.u.i. piece over msd. Thanks, Greg |
| Author: | Rick Covalt [ Wed Nov 27, 2019 4:10 pm ] |
AC/Delco ones are on Rock Auto for $20 couple bucks? |
| Page 1 of 2 | All times are UTC-08:00 |
