It is currently Thu Nov 12, 2026 12:16 am
PostPosted: Mon Jan 20, 2020 7:48 pm
Car Model: custom roadster
I understand the Carter 6537s was a standard 2-barrel carburetor on '74-'83 Dodge trucks. I've read good things about the later Carter carbs on this forum. Questions:
(1) Does anyone have experience running a matching pair of 6537s on a dual-carb intake?
(2) Short of actual experience, do folks have any opinions about how such a setup might behave?
(My search for "6537s" yielded this thread: http://www.slantsix.org/forum/viewtopic.php?f=1&t=62251)
PostPosted: Mon Jan 20, 2020 10:27 pm
a matching pair of [Carter] 6537s on a dual-carb intake
Oorrr is that way too much carb? I should go to sleep.
PostPosted: Tue Jan 21, 2020 6:55 am
Car Model: 1964 Dart 270
How much power you expecting?
Two Weber 34 ICH's with 29mm chokes are good for upwards of 200hp and is the setup I am contemplating. There are guys in Europe running them on old Ford V4's making 100hp with one of those carbs. The Weber carb book says the 29mm choke on a plenum manifold is good for 5k rpm peak power on half of a 225, more rpm on a 170/198.
If that isn't enough carb you can do two 32/36. Some people have problems setting those up because of the progressive nature of them. That can be remedied by buying a linkage that makes them open at the same time from Pegasus racing. There is still a racing class using those carbs to 140-150 hp on a pinto motor.
Weber carbs are a much better option than old Carters. Still made new and lots of jets and such for tuning. ICH has a power valve and lots of adjustment, it is a shame that they don't come in a size to replace the BBS.
____________________________
https://www.flickr.com/photos/162600228@N03/
PostPosted: Tue Jan 21, 2020 7:08 am
Two Weber 34 ICH's with 29mm chokes are good for upwards of 200hp...
That's my answer, right there. I'd better stick to 2x 1BBL; I'm expecting less than 200hp. Thank you!
