| Turbo with AC ? https://slantsix.org/forum/viewtopic.php?t=64309 |
| Author: | dpw21562 [ Sat Dec 14, 2019 8:16 am ] |
| Post subject: | Turbo with AC ? |
New to turbos but want to do it to the slant six. But the big problem is that I need AC in warm weather. Has this been done ? Thanks. |
| Author: | bmimken [ Wed Dec 18, 2019 12:27 am ] |
| Post subject: | Re: Turbo with AC ? |
Yes, I have A/C and run a turbo. But my build is very different than most turbo builds. I have a rear mounted turbo under the car behind the rear axle. Left me with plenty of room for A/C. For most conventional turbo builds, the only available space for A/C would be to use a manual steering box and try to mount it where the power steering unit usually resides. Definitely would have to run a modern Sanden type compressor due to the tight quarters there. Brian |
| Author: | MJF [ Wed Dec 18, 2019 2:37 am ] |
https://www.youtube.com/channel/UClJr9M ... hbA/videos Check his Duster build. I believe there is turbo, AC and powersteering. |
| Author: | Dart270 [ Wed Dec 18, 2019 11:30 am ] |
Sam Powell did it on his 69 Dart with a Buick GN turbo and sanden compressor. PS too, IIRC. Try searching this site. He has passed away and the car was sold. Lou |
| Author: | Greg Ondayko [ Wed Dec 18, 2019 11:49 am ] |
Power steering is easier with a modern pump and relocated reservoir like many modern cars use. Gref |
