Transmission to engine bracket
https://slantsix.org/forum/viewtopic.php?t=64326
Page 1 of 1
Author:  GregCon [ Fri Dec 20, 2019 6:25 am ]
Post subject:  Transmission to engine bracket
I should know this....but I don't. This bracket is for an automatic trans-to-Slant six block. Does a manual trans use a different bracket? Or the same?
Author:  nuttyprof [ Fri Dec 20, 2019 8:39 am ]
Post subject:  Re: Transmission to engine bracket
Not positive but I think they are the same.
Author:  hyper_pak [ Fri Dec 20, 2019 8:55 am ]
There is a wider one.
It has a tab for a return spring.
Manual Transmission.
Author:  GregCon [ Fri Dec 20, 2019 12:08 pm ]
Thanks! I recognized it the minute I saw your photo. Now I gotta go see if I can find one...
Author:  DusterIdiot [ Fri Dec 20, 2019 4:58 pm ]
Post subject:  D
D
Author:  hyper_pak [ Fri Dec 20, 2019 5:29 pm ]
If you need one give me a shout, I have a few.
Author:  Greg Ondayko [ Fri Dec 20, 2019 5:53 pm ]
They are different.
If you only had an a904 auto bracket you could cut and weld it into a manual trans bracket if you really needed to.
Author:  nuttyprof [ Fri Dec 20, 2019 6:13 pm ]
I guess I spoke out of turn. :oops: :oops: :(
Author:  hyper_pak [ Sat Dec 21, 2019 12:22 pm ]
Na, we are just a bunch of know it alls.
