It is currently Tue Nov 17, 2026 5:07 am
 Post subject: Testing an engine
PostPosted: Wed Dec 18, 2019 10:00 am
Car Model: 1962 Dodge Dart
Hi guys,
I can bolt my auto torque converter (with ring gear) back onto the engine just to test the engine correct?
Paul
 Post subject: Re: Testing an engine
PostPosted: Wed Dec 18, 2019 10:31 am
The converter needs to be supported at both ends so it needs to have the transmission with it.
Use a manual transmission bell housing and flywheel if you need to run an engine on a dyno or on a test stand.
PostPosted: Wed Dec 18, 2019 11:24 am
Got you,
Thanks DD. Finding the flywheel has been my problem, I have yet to find anything after two weeks.
Paul
PostPosted: Wed Dec 18, 2019 6:03 pm
Where are you located? There has to be some flywheels close to you I would think.
PostPosted: Sun Dec 22, 2019 8:48 pm
Phoenix Rick,
You wouldn't think would you? But, it took two weeks, abut 10 hours looking on the Internet and eight phone calls before I found 1 in Nebraska. Hopefully it will be here the next couple of days! Also, how big of an issue are a couple broken ring gear teeth?
Paul
Users browsing this forum: Ahrefs [Bot] and 7 guests
