Bmw coil connect boot
https://slantsix.org/forum/viewtopic.php?t=64330
Author:  Greg Ondayko [ Sat Dec 21, 2019 12:15 pm ]
Post subject:  Bmw coil connect boot
Hi all,
As per Matt Cramer's recommendation i got a 1988 bmw to to try with my megasquirt.
It has a different boot / plug end to connect to the distributor cap.
What is this type of boot called that i need to buy for my coil wire?
It seems different than the typical usa hei/ oe stuff that I am used to.
Author:  DadTruck [ Sat Dec 21, 2019 6:54 pm ]
Post subject:  Re: Bmw coil connect boot
I don’t know the exact boot/coil wire that you need, but I bet that a custom ignition wire source like Magnecor would.
Author:  Greg Ondayko [ Sun Dec 22, 2019 10:21 am ]
Thanks John. I forgot what valuable resource they have there.
Author:  emsvitil [ Sun Dec 22, 2019 6:16 pm ]
Can you screw a spark plug nipple on it?
Then use an appropriate spark plug wire end....
