| Switching from rod to cable throttle linkage https://slantsix.org/forum/viewtopic.php?t=64348 |
| Author: | 64 Convert [ Sun Dec 29, 2019 9:09 am ] |
| Post subject: | Re: Switching from rod to cable throttle linkage |
I put a cable operated linkage in my '64 slant Valiant, and it was simple. I can't remember the donor car, but it was a Mopar...probably a truck. The bracket mounts flat against firewall without any problems. I'm also using a Duster pedal with cable linkage on a modified '56 Plymouth, and it was a bit more difficult. |
| Author: | AbodiesRule [ Sun Dec 29, 2019 10:43 am ] |
Thanks 64Convert! I'm guessing you just drilled new holes for the bolts and cable through the firewall? It doesn't look like the new set up will line up with the previous hole for the rod system. |
| Author: | 64 Convert [ Sun Dec 29, 2019 6:31 pm ] |
That's correct. It was easy to calculate the location and the cable length is forgiving. Mine was a little longer than needed, but I just put a small loop in it. |
| Author: | kesteb [ Tue Dec 31, 2019 11:23 pm ] |
I used one from a '75 Dart. I removed the flange, welded up the holes, and drilled new ones. The best place is where it is most comfortable for your foot. |
