| Is this an A833OD bell housing? https://slantsix.org/forum/viewtopic.php?t=64374 |
| Author: | rosspulliam [ Fri Jan 03, 2020 2:49 pm ] |
| Post subject: | Is this an A833OD bell housing? |
It's me again, hoping to make sure I'm IDing parts correctly. Is this the correct A833OD bell housing? It's listed as out of a 1980 Van with a 225, but the transmission type isn't listed. I've asked the seller to provide casting numbers that I can possibly reference, but he hasn't gotten back to me yet. It looks correct from my google image searches and the 4 speed article, but any validation is appreciated. |
| Author: | Joshie225 [ Fri Jan 03, 2020 4:16 pm ] |
| Post subject: | Re: Is this an A833OD bell housing? |
Yes. The A230 3-speed will also fit. |
| Author: | rosspulliam [ Fri Jan 03, 2020 4:17 pm ] |
Quote: Yes. The A230 3-speed will also fit.
Thanks!
| Author: | GregCon [ Fri Jan 03, 2020 5:45 pm ] |
Measure the diameter of the hole in back, the one where the transmission registers. It should be a bit over 5". If it's under, it is not for an OD 833 |
| Author: | rosspulliam [ Fri Jan 03, 2020 8:53 pm ] |
Quote: Measure the diameter of the hole in back, the one where the transmission registers. It should be a bit over 5". If it's under, it is not for an OD 833
I asked him to as that was my thought for confirmation. I'll see if I can get him to do it when I call back tomorrow.
| Author: | Dart270 [ Sat Jan 04, 2020 1:54 am ] |
Looks right to me. IIRC, the hole diam is 5.125" Lou |
| Author: | Joshie225 [ Sat Jan 04, 2020 8:55 am ] |
Quote: Quote: Measure the diameter of the hole in back, the one where the transmission registers. It should be a bit over 5". If it's under, it is not for an OD 833
I asked him to as that was my thought for confirmation. I'll see if I can get him to do it when I call back tomorrow. |
| Author: | GregCon [ Sat Jan 04, 2020 9:51 am ] |
Yes, it's right around 5-1/8". But I find that my level of disappointment increases radically when I ask a seller to measure anything in smaller than 1" increments. I once asked a seller on Ebay to tell which side of the car a bracket was for. He replied "It's goes on the North side." |
| Author: | Dart270 [ Sat Jan 04, 2020 11:16 am ] |
Yes, good point, Greg. I understood you were trying to make it easy on the seller, just throwing out the spec number... Lou |
| Author: | rosspulliam [ Sat Jan 04, 2020 4:27 pm ] |
Quote: Quote: Quote: Measure the diameter of the hole in back, the one where the transmission registers. It should be a bit over 5". If it's under, it is not for an OD 833
