| downside of increased compression? https://slantsix.org/forum/viewtopic.php?t=64501 |
Page 1 of 3 |
| Author: | rich006 [ Thu Feb 13, 2020 8:58 am ] |
| Post subject: | downside of increased compression? |
Is there any downside to increasing compression ratio? I mean aside from the inability to run regular gasoline if you go too far. Surely there must be some downside or the factory would have built it with higher compression from the beginning, right? I'm guessing increased wear on bearings, cylinder walls, etc that could shorten engine life. Thoughts? |
| Author: | Reed [ Thu Feb 13, 2020 9:11 am ] |
| Post subject: | Re: downside of increased compression? |
Higher NOx emissions. Faster wear on mechanical parts. |
| Author: | DadTruck [ Thu Feb 13, 2020 9:37 am ] |
Quote: or the factory would have built it with higher compression from the beginning
possibly, but the slant was intended to be an economy vehicle, manufactured as 'economic' as possible.the fact that the actual compression found is typically much lower than what the engine seemed to be listed as having is likely the result of loose manufacturing tolerances and even poorer manufacturing capability/expectations. the lower compression as Reed mentioned helped engine life as well as made the engine turn over and start easier. Certainly would have help battery and starter life. |
| Author: | DusterIdiot [ Thu Feb 13, 2020 6:00 pm ] |
The above comments have merits up to a certain point. Economics do play into the grocery getting utility engine... literally a couple hundred bux could up grade you to a V-8 car so why spend more on a small mill that won't approach the big block at the time without spending the amount of money to make a V-8 anyway. Right now a fair amount of modern vehicles run in the 9-10:1 SCR range, and some high end vehicles are running up to 12:1 on the street. Part of this is the available technology and engineering knowledge that wasn't available when our engine was designed and 20 years before that the vehicles going to war were using even lower compression and using high drive ratios to keep the engine happy on petro that was crudely refined by todays standards. An issue that does occur with engine longevity is the fact that when an end user goes from driving a stock 1 barrel car to a hipo slant...a lot of aggressive driving ensues and it hammers the drive and powertrain shortening the life of the build...on the top end, the guys wringing all the power out of the engine to get across the line faster are beyond the original design specs and safety margin of the engine and it will wear out from repeated 1/4 mile runs. Routine maintenance and less abuse will help things last longer...(along with good engineering when thinking out the build and rebuilding the mill). You shouldn't have any problems keeping a 9:1 SCR engine together for 100K+ miles in a daily driver as long as you aren't hammering it light to light, or pulling repeated hyperpak clutch dumps... 10:1 SCR if thoughtfully put together will last a similar amount 11:1 and 12:1 can be streeted but the build will not be an MPG car and may not last as long as you will be racing it a bit to see what it really can do. Designing with the DCR in mind and adjusting the cam specs along with matching to the drive ratios and rpm will help decide how much knock needs to be supressed with higher octane, less timing, or other methods... NOx is a product of high cylinder pressure and temps...which will occur but can be lowered through use of EGR, timing, catalytic convertors...it isn't even considered in race cars, but if the car is to be smogged, you may need to keep it all stock to keep the regulating body happy and get your registration renewed. Keep asking questions, hone in on what you want to achieve and build for the here and now. (...and be thankful the Ford Nucleon didn't get built, we'd have had a completely different discussion on engine longevity...LOL) |
| Author: | drgonzo [ Thu Feb 13, 2020 9:33 pm ] |
Nucleon....I had to google that! |
| Author: | rich006 [ Fri Feb 14, 2020 5:26 am ] |
Would you ever consider adding a catalytic converter to a car that didn't come with one? Let's say one of your goals is to minimize the stink in your exhaust.
EGR, timing, catalytic convertors... Keep asking questions, hone in on what you want to achieve and build for the here and now. |
| Author: | GregCon [ Fri Feb 14, 2020 5:35 am ] |
Not bad arguments, certainly as theory, but it's been well proven in the real world that high compression has no 'visible' effect on reliability. There are way too many engines from all makers running 10:1 or more that last forever. As for compression ratios, my daily driver is right at 13.0:1 which places it well into 'high end' territory. It burns regular gas in small amounts, puts out over 1HP/cubic inch, and is bone stock. I have 100K miles on it and I have no reason to think it won't go to 300 or 400K if I keep changing the oil. |
| Author: | Reed [ Fri Feb 14, 2020 8:21 am ] |
Would you ever consider adding a catalytic converter to a car that didn't come with one? Let's say one of your goals is to minimize the stink in your exhaust.EGR, timing, catalytic convertors... Keep asking questions, hone in on what you want to achieve and build for the here and now. |
| Author: | GregCon [ Fri Feb 14, 2020 8:46 am ] |
Yep. The converter will die soon enough if you run it on a carb'd engine then your smelly exhaust is back. Reminds me of the guy who told me, back around 1977, that he was going to buy a cadillac converter so he could convert his Pontiac into a Caddy. |
| Author: | Reed [ Fri Feb 14, 2020 10:39 am ] |
Although a few years back I got a 1982 Dodge Ramcharger that was built with a carb and a cataytic converter. I replaced the original catalytic converter with a new high-flow three-way converter and it seems to be holding up well, so far. |
| Author: | DusterIdiot [ Fri Feb 14, 2020 7:12 pm ] |
Quote: There are way too many engines from all makers running 10:1 or more that last forever.
I guess when the slant six time machine shows back up and they bring back proof that a Morlock actually has a running 10:1 engine in 802,701 AD we'll take that as fact... until then we are looking at limited examples that have survived about 80 years so far... Most of any engines that will survive a human lifetime will be because they are maintained, cared for, and not abused... |
| Author: | Thebearded1 [ Fri Feb 14, 2020 7:22 pm ] |
Quote: Is there any downside to increasing compression ratio? I mean aside from the inability to run regular gasoline if you go too far. Surely there must be some downside or the factory would have built it with higher compression from the beginning, right? I'm guessing increased wear on bearings, cylinder walls, etc that could shorten engine life. Thoughts?
Where are you planning to have the machining down for your head/block? I'm in MD too and will be looking to have a head done.Thanks Gene |
| Author: | Reed [ Fri Feb 14, 2020 9:39 pm ] |
Quote: Most of any engines that will survive a human lifetime will be because they are maintained, cared for, and
Thats what Eloi are for.
not abused... |
| Author: | rich006 [ Sat Feb 15, 2020 3:36 am ] |
I have a couple of machinists' names. Both were personally recommended by good mechanics. I plan to visit their shops to get a feel for how they operate (and how interested they are in my project) before I make a decision. I'll start a new thread about my build. The reason I asked the question in this thread is because I saw a post on FABO where someone claimed that increasing compression has no downside. It sounded too good to be true.Walt (Charlie's Machine, Wicklow Rd, near BWI airport) 410-760-5014 Woody (Mayo Rd, Edgewater, MD) 410-798-5806 I'm not sure if they have last names, LOL. |
| Author: | Thebearded1 [ Sat Feb 15, 2020 4:42 am ] |
| Page 1 of 3 | All times are UTC-08:00 |
