| has head been decked https://slantsix.org/forum/viewtopic.php?t=64505 |
| Author: | Thebearded1 [ Fri Feb 14, 2020 6:02 pm ] |
| Post subject: | has head been decked |
I purchased a used head that is clean but the seller didn't know anything on it. Is there any measurement I can take to see if it has been milled at all? Thanks Gene |
| Author: | Badvert65 [ Fri Feb 14, 2020 6:15 pm ] |
| Post subject: | Re: has head been decked |
I think your best bet is to cc the combustion chambers. |
| Author: | Rick Covalt [ Sat Feb 15, 2020 4:52 am ] |
There was a post one time by Charlie Schmid that measured from the valve cover rail to the face of the head to give you an idea? At least i think it was him! |
| Author: | Charrlie_S [ Sat Feb 15, 2020 4:55 am ] |
Quote: There was a post one time by Charlie Schmid that measured from the valve cover rail to the face of the head to give you an idea? At least i think it was him!
Yes. I will have to go out to the shop to get that dimension.
| Author: | Rick Covalt [ Sat Feb 15, 2020 5:52 am ] |
3.600" sticks in my head?? |
| Author: | Charrlie_S [ Sat Feb 15, 2020 8:01 am ] |
Quote: 3.600" sticks in my head??
Pretty good memory. I get 3.610 to 3.600
| Author: | Thebearded1 [ Sat Feb 15, 2020 8:59 am ] |
Thanks guys I figured there was something like this so I could ballpark it! Now I just have to dig the head out and see. |
| Author: | hyper_pak [ Sat Feb 15, 2020 9:40 am ] |
It would be good to CC it anyway. Write it down and then you can have it for later mods. Also Piston height while head is off. You can CC on the cheap with a little piece of plastic, a 100 CC syringe and some rubbing alcohol. |
