It is currently Sun Nov 15, 2026 2:14 pm
PostPosted: Sun Mar 01, 2020 6:31 pm
Car Model: 1965 Dodge A100 Pickup w/Super Six
How many quarts are needed to change oil in a 225 slant? My manual (Dodge A100 Trucks and Vans) says a 225 slant oil change uses 4 quarts plus some for the filter. I changed oil and filter, put in 4 quarts, short. Put in the 5th quart, still a quart shy. Now I don't trust my dipstick. What do you think??? Thanks! Gary
PostPosted: Sun Mar 01, 2020 7:04 pm
My 83 D150 with a tall filter takes nearly 6 quarts to get oil level to the full mark.
PostPosted: Mon Mar 02, 2020 3:20 am
Most cars take 5, but like John said, my truck takes nearly 6 to fill it. Mine is an 85 D100
PostPosted: Mon Mar 02, 2020 3:22 am
Trucks /vans usually 6 qts.. with filter.
Cars usually 5 qts with filter.
If the stick says add then add.
Unless the dipstick is not matched to the pan somehow.. if that's the case I would say 6 qts will be okay unless you are autocrossing or doing other extreme driving.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 6 guests
