| How much oil in a slant oil change? https://slantsix.org/forum/viewtopic.php?t=64562 |
| Author: | a100gary [ Sun Mar 01, 2020 6:31 pm ] |
| Post subject: | How much oil in a slant oil change? |
How many quarts are needed to change oil in a 225 slant? My manual (Dodge A100 Trucks and Vans) says a 225 slant oil change uses 4 quarts plus some for the filter. I changed oil and filter, put in 4 quarts, short. Put in the 5th quart, still a quart shy. Now I don't trust my dipstick. What do you think??? Thanks! Gary |
| Author: | DadTruck [ Sun Mar 01, 2020 7:04 pm ] |
| Post subject: | Re: How much oil in a slant oil change? |
My 83 D150 with a tall filter takes nearly 6 quarts to get oil level to the full mark. |
| Author: | Rick Covalt [ Mon Mar 02, 2020 3:20 am ] |
Most cars take 5, but like John said, my truck takes nearly 6 to fill it. Mine is an 85 D100 |
| Author: | Greg Ondayko [ Mon Mar 02, 2020 3:22 am ] |
Trucks /vans usually 6 qts.. with filter. Cars usually 5 qts with filter. If the stick says add then add. Unless the dipstick is not matched to the pan somehow.. if that's the case I would say 6 qts will be okay unless you are autocrossing or doing other extreme driving. Greg |
