Timing issue?
https://slantsix.org/forum/viewtopic.php?t=64625
Page 1 of 1
Author:  Pgbarrow [ Wed Mar 18, 2020 6:16 pm ]
Post subject:  Timing issue?
Hi all,
I attempted to start my engine up the other night and I did get somewhere with it. To recap, my engine is currentry out of the car and sitting on a stand. After fuel reached the carburator, I got some noise! However, it did not seem to be firing correctly as it would not run once I got off the starter. The best I did was get a constant burbling sound. I stopped trying to crank it once the starter started to smoke (oops). There was definitely some combustion going on as the engine got warm. Does this sound like a timing issue to you guys? I was going to try loosening the dirstibutor and adjusting it around for my next try.
Paul
Author:  Louise76 [ Wed Mar 18, 2020 8:37 pm ]
Post subject:  Re: Timing issue?
Distributor timed to #1 compression stroke? Or, following the K.I.S.S. principle, check the wires going to the correct cylinders in the correct direction of distributor rotation? I say this 'cuz that's where I'd screw things up myself!
Author:  Pgbarrow [ Thu Mar 19, 2020 9:11 am ]
Hi Louise,
To adjust the distributor I loosen the lock nut underneath the distributor on the left side when looking at it correct?
Paul
Author:  Louise76 [ Thu Mar 19, 2020 10:02 am ]
(On my 1975 /6) technically, it is not a lock nut. It is a bolt through a clamp plate holding the base of the distributor tightly in place. Yes, loosen the clamp bolt to rotate the distributor.
Author:  Pgbarrow [ Thu Mar 19, 2020 12:16 pm ]
Ok,
Thank you Louise. I will take a look at that next.
Paul
