It is currently Thu Apr 30, 2026 4:16 am
PostPosted: Sat Aug 09, 2003 12:45 am
I was wondering if this would be a good alternative to my 7 1/4? This one is out of a jeep so it is narrow enough for my car and it has the 5x4 1/2" lug pattern. But now the bad news, 4.11 gears in it.
-Jesse
PostPosted: Sun Aug 10, 2003 12:11 am
Car Model: 1964 Valiant
I believe a Dana 44 is 8.5" ring. Used in lots of vehicles, even Corvette used them in '82. It ought to be plenty strong.
PostPosted: Sun Aug 10, 2003 1:37 am
What are the chances a jeep having perches in same spot as an A body?
PostPosted: Sun Aug 10, 2003 7:52 am
it's pretty easy to move the spring pads - My Dad and I did a rear end for an 86 Mazda - we were using an 84 Rear end that was 3" or so narrower.
cut them off with a grinder, grind the slag off, measure 3 times, weld them back up.
Joe
My 63 Valiant
http://www.readersrides.com/rides/class ... aliant.htm
<img src="http://www.readersrides.com/slant6-02.gif"/>
PostPosted: Sun Aug 10, 2003 2:48 pm
Well the pads are real close, but they're on top of the tubes and I need them on the bottom. I'm just worried about the U-joints not working, i haven't pulled the inspection cover to verify the gearing or if it does have a posi unit.
-Jesse
