| Direct Connection cam and tappet kit. https://slantsix.org/forum/viewtopic.php?t=64697 |
| Author: | siverlyboy [ Sat Apr 04, 2020 6:34 pm ] |
| Post subject: | Direct Connection cam and tappet kit. |
I have a brand new in the box cam kit from Direct Connection. The part number on the Box is 4286679 but inside the box is a long skinny box with a new cam in it with the part #4286678. Is anyone familiar with what I have ? Which number is the correct number for the cam ? What are the characteristics of this cam ? |
| Author: | and739 [ Sun Apr 05, 2020 5:30 am ] |
| Post subject: | Re: Direct Connection cam and tappet kit. |
I found this by Googling “Direct Connection 4286679” it links back to the Articles page of this website. http://www.slantsix.org/articles/racing ... index.html Tons of info right there. Enjoy |
| Author: | hyper_pak [ Sun Apr 05, 2020 9:05 am ] |
Usually casting numbers are 1 number apart from Part Numbers. Usually. |
| Author: | slantzilla [ Sun Apr 05, 2020 9:15 pm ] |
One number is for the cam, the other for the whole kit. |
| Author: | drgonzo [ Mon Apr 06, 2020 6:16 am ] |
Info I've collected on cams says that #4286679 is the 268 degree .476 lift grind. |
| Author: | Dart270 [ Mon Apr 06, 2020 8:50 am ] |
Good midrange cam. Would not run it with less than 2400 RPM stall converter, and I would personally use 2800. Lou |
| Author: | Joshie225 [ Mon Apr 06, 2020 8:51 am ] |
You can find the cam listed in this chart: https://drive.google.com/open?id=1gLMI6 ... Vt1m3PDbaI |
