It is currently Tue Nov 17, 2026 4:51 pm
PostPosted: Wed Apr 22, 2020 2:30 pm
Online
Drop in Drilled / Slotted 5 on 4.5" 10.87"Ø Front Rotors...
Ignore the picture on the link..
https://www.summitracing.com/parts/bhi-05314-020
They look like this... Ignore the Long Studs.. I pressed those ones in... They come with normal stock type studs.
So far so good for me on the '64 dart!
PostPosted: Wed Apr 22, 2020 3:50 pm
So you just drilled your small pattern hubs to match and you have 4 piston brakes with 4.5 pattern? Or are these for the single piston brakes?
PostPosted: Wed Apr 22, 2020 4:09 pm
Online
No, this car has 4 on 4.5 rotors.
F body spindles... single piston 73 up a body f body etc.
PostPosted: Wed Apr 22, 2020 4:10 pm
Thanks Greg.
PostPosted: Wed Apr 22, 2020 4:14 pm
Just curious, what does each rotor weigh?
PostPosted: Wed Apr 22, 2020 4:20 pm
Online
I didn't weigh them
I would guess close to stock, but need to get a good scale to confirm.
