It is currently Tue Nov 17, 2026 3:46 pm
PostPosted: Sat Apr 04, 2020 6:34 pm
I have a brand new in the box cam kit from Direct Connection. The part number on the Box is 4286679 but inside the box is a long skinny box with a new cam in it with the part #4286678. Is anyone familiar with what I have ? Which number is the correct number for the cam ? What are the characteristics of this cam ?
PostPosted: Sun Apr 05, 2020 5:30 am
Car Model: 1975 Dodge D100
I found this by Googling “Direct Connection 4286679” it links back to the Articles page of this website.
http://www.slantsix.org/articles/racing ... index.html
Tons of info right there.
Enjoy 8)
PostPosted: Sun Apr 05, 2020 9:05 am
Usually casting numbers are 1 number apart from Part Numbers. Usually.
PostPosted: Sun Apr 05, 2020 9:15 pm
One number is for the cam, the other for the whole kit.
PostPosted: Mon Apr 06, 2020 6:16 am
Info I've collected on cams says that #4286679 is the 268 degree .476 lift grind.
PostPosted: Mon Apr 06, 2020 8:50 am
Good midrange cam. Would not run it with less than 2400 RPM stall converter, and I would personally use 2800.
PostPosted: Mon Apr 06, 2020 8:51 am
You can find the cam listed in this chart:
https://drive.google.com/open?id=1gLMI6 ... Vt1m3PDbaI
