Compression Ratio ?
https://slantsix.org/forum/viewtopic.php?t=64732
Author:  siverlyboy [ Fri Apr 10, 2020 12:46 pm ]
Post subject:  Compression Ratio ?
Trying to compute my compression Ratio.
Block
.06 over
.198 in the hole
.040 thick Felpro Headgasket.
Head 44 CC'S
Any other info needed ?
Author:  ProCycle [ Fri Apr 10, 2020 2:53 pm ]
Post subject:  Re: Compression Ratio ?
If there's any dish or valve cutouts in the piston top you need to CC them.
Don't forget to calculate the volume between the piston crown and cylinder above the top ring.
Author:  Badvert65 [ Fri Apr 10, 2020 2:57 pm ]
I get a compression ratio of 8.88 using the Wallace Racing site.
http://wallaceracing.com/cr_test2.php
Author:  Doctor Dodge [ Sat Apr 11, 2020 11:43 am ]
I get 8.866 on the UEM (Silvolite) calculator.
7.983 Effective Compression if the intake valve closes at 46 ABDC.(a "small" cam)
