It is currently Sat Nov 14, 2026 10:03 am
 Post subject: valve adjustment
PostPosted: Sun Aug 10, 2003 3:36 pm
ok, im really stumped now. i adjusted the valves (they were WAY out and i havent done it since the purchase in june) and went to the track. the car went slower. it was a little humid out so i exected it to maybe match its best low 19 times from before. but it went back to mid 19s were it was before i did any real work on it. what do you think is up with this? i adjusted them to .008/.020 like doc said. man, i have to say its nice not to here all that clattering like before though.
--chad
74 swinger slant 6, the slowest, most fun car i have ever owned.
PostPosted: Sun Aug 10, 2003 9:48 pm
Don't want to go against Doug, but try setting the intakes at .010" and see what happens. Could be that you don't need the intakes that tight.
PostPosted: Mon Aug 11, 2003 12:02 am
Try some looser settings and see if the engine likes it.
Bottomline is that you can "play" with the lash adjustment to find the best performance, with your engine, tighter may not be "better" but you need to see if looser really helps.
On the other hand, there could be something else which slowed the car down.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 13 guests
