| Report / review on camshaft https://slantsix.org/forum/viewtopic.php?t=64770 |
| Author: | frank79912 [ Fri Apr 17, 2020 6:40 am ] |
| Post subject: | Report / review on camshaft |
I am finally changing mine. Before I committed to the cam grind , I would like to know what everybody is running and how the cam performs ,especially in the low /lower rpm ranges. |
| Author: | Joshie225 [ Fri Apr 17, 2020 7:50 am ] |
| Post subject: | Re: Report / review on camshaft |
Why are you changing your camshaft? If you're going to bother changing the cam and the vehicle is not a truck with the A727 and a 12" torque converter I would go straight to Oregon Cam grinding and ask for the #819 intake lobe, 818 exhaust lobe on 108° LSA. You might want to know that a lot of performance is choked off by the stock carburetor and cylinder head. So again, why are you changing your camshaft? |
| Author: | volaredon [ Fri Apr 17, 2020 8:02 am ] |
what WOULD you suggest with a slant in a truck with an 727 trans? Cuz that's what I have..... along with 3.2 rear gears. I also have a super 6 combo here that will go on. see how that goes and maybe move up from there eventually. current is the stock 85 hydro/cast crank slant but I have a 74 forged crank motor here that I want to beef up and stab in there eventually.... plan on block and head shave, amounts to be yet determined, the cam suggestion would be for the new engine. |
| Author: | frank79912 [ Fri Apr 17, 2020 1:59 pm ] |
I am not asking for suggestions-I am asking how the cam you have performs. |
| Author: | ProCycle [ Fri Apr 17, 2020 2:22 pm ] |
That may seem like a simple question but how well any particular cam performs depends a great deal on how well the motor was set up around the design of the cam. |
| Author: | Reed [ Fri Apr 17, 2020 2:38 pm ] |
Quote: what WOULD you suggest with a slant in a truck with an 727 trans? Cuz that's what I have..... along with 3.2 rear gears. I also have a super 6 combo here that will go on. see how that goes and maybe move up from there eventually. current is the stock 85 hydro/cast crank slant but I have a 74 forged crank motor here that I want to beef up and stab in there eventually.... plan on block and head shave, amounts to be yet determined, the cam suggestion would be for the new engine.
Trying to avoid a thread hijack. Volaredon- read HEREBack to the regularly scheduled thread topic of how everyone's cam performs. I am running a stock cam (I think) in my 1976 D100. My truck is basically all stock except I added a two barrel carb. It is a 225 backed by a 727 and a 9 1/4 rear axle with 3.9 gears. It is a dog. The engine happily spin fast enough to get the truck up to 70+ on the highway but accelleration in terrible. I am sure I have problems with the carb and transmission, plus the 727 is really too much trans for this engine. Ultimately, I plan on building a higher compression ratio engine and will be switching to a different camshaft. You can do quite a bit with the stock cam in a pasenger car. More benefits come from compression increase and bigger valves or forced indiction than a cam swap. |
| Author: | Joshie225 [ Fri Apr 17, 2020 3:12 pm ] |
Quote: I am not asking for suggestions-I am asking how the cam you have performs.
Ah, sure. There's a search function for that. Plenty of field reports.
