Drop in Drilled / Slotted 5 on 4.5 10.87" Front Rotors
https://slantsix.org/forum/viewtopic.php?t=64790
Page 1 of 1
Author:  Greg Ondayko [ Wed Apr 22, 2020 2:30 pm ]
Post subject:  Drop in Drilled / Slotted 5 on 4.5 10.87" Front Rotors
Drop in Drilled / Slotted 5 on 4.5" 10.87"Ø Front Rotors...
Ignore the picture on the link..
https://www.summitracing.com/parts/bhi-05314-020
They look like this... Ignore the Long Studs.. I pressed those ones in... They come with normal stock type studs.
So far so good for me on the '64 dart!
Author:  drgonzo [ Wed Apr 22, 2020 3:50 pm ]
Post subject:  Re: Drop in Drilled / Sotted 5 on 4.5 10.87" Front Rotors
So you just drilled your small pattern hubs to match and you have 4 piston brakes with 4.5 pattern? Or are these for the single piston brakes?
Author:  Greg Ondayko [ Wed Apr 22, 2020 4:09 pm ]
No, this car has 4 on 4.5 rotors.
F body spindles... single piston 73 up a body f body etc.
Author:  drgonzo [ Wed Apr 22, 2020 4:10 pm ]
Thanks Greg.
Author:  Badvert65 [ Wed Apr 22, 2020 4:14 pm ]
Just curious, what does each rotor weigh?
Author:  Greg Ondayko [ Wed Apr 22, 2020 4:20 pm ]
I didn't weigh them
I would guess close to stock, but need to get a good scale to confirm.
