| Cylinder Hone https://slantsix.org/forum/viewtopic.php?t=64792 |
| Author: | siverlyboy [ Wed Apr 22, 2020 10:31 pm ] |
| Post subject: | Cylinder Hone |
I have a engine that the cylinders need a light cleaning and the cross hatch reestablished. The bore is straight and true I checked it with a bore gage it's also has a .060 overbore. I would like to buy a flexhone. What Grit and size should I get ? |
| Author: | drgonzo [ Thu Apr 23, 2020 8:02 am ] |
| Post subject: | Re: Cylinder Hone |
I went with a 3.5", 240 grit but I haven't used it yet. |
| Author: | Joshie225 [ Thu Apr 23, 2020 10:51 am ] |
The grit depends upon the rings you plan to use. Plain cast rings use a slightly rougher finish than moly. I don't expect you'll use chrome. Also, be sure to read the hone instructions and watch some of the Brush Research videos. |
| Author: | siverlyboy [ Fri Apr 24, 2020 5:46 pm ] |
I plan on using just plain old cast .060 Rings. |
| Author: | Joshie225 [ Fri Apr 24, 2020 6:25 pm ] |
A fine choice. And congratulations on putting the overbore decimal in the proper place! Here's the video showing the proper use of the Flex-Hone: https://youtu.be/jgDUzOxg2MU |
