It is currently Fri Nov 20, 2026 6:51 pm
 Post subject: 66 to 61 A-body oil pan
PostPosted: Sat Apr 25, 2020 7:36 am
I am currently putting a 1961 slant six 170 into a 1966 Plymouth Valiant- and I'm encountering some issues with the oil pan hitting the K-frame. The engine is out of a '61 Lancer. I checked the oil pan for a part number, and it is stamped with 987. The engine came out of an A-body car, so I figured it would work. Could anyone tell me if I can make this pan work and if not then what style/year of oil pan do I need?
Thank you for all the help.
PostPosted: Sat Apr 25, 2020 8:52 am
The 60 - 66 A body pan does not have any numbers stamped onto it so it and it has the sump pretty far back.
It sounds like you need to swap-on the correct oil pan and pick-up tube to get everything to fit.
Is the crankshaft rear counter bore the correct size for the torque converter?
PostPosted: Sun Apr 26, 2020 8:13 am
Yes, the crankshaft is the correct size for the torque converter.
Users browsing this forum: Ahrefs [Bot] and 7 guests
