| 66 to 61 A-body oil pan https://slantsix.org/forum/viewtopic.php?t=64802 |
| Author: | smcollins00 [ Sat Apr 25, 2020 7:36 am ] |
| Post subject: | 66 to 61 A-body oil pan |
I am currently putting a 1961 slant six 170 into a 1966 Plymouth Valiant- and I'm encountering some issues with the oil pan hitting the K-frame. The engine is out of a '61 Lancer. I checked the oil pan for a part number, and it is stamped with 987. The engine came out of an A-body car, so I figured it would work. Could anyone tell me if I can make this pan work and if not then what style/year of oil pan do I need? Thank you for all the help. |
| Author: | Doctor Dodge [ Sat Apr 25, 2020 8:52 am ] |
| Post subject: | Re: 66 to 61 A-body oil pan |
The 60 - 66 A body pan does not have any numbers stamped onto it so it and it has the sump pretty far back. It sounds like you need to swap-on the correct oil pan and pick-up tube to get everything to fit. Is the crankshaft rear counter bore the correct size for the torque converter? DD
| Author: | smcollins00 [ Sun Apr 26, 2020 8:13 am ] |
Yes, the crankshaft is the correct size for the torque converter. |
