| Will slant six 904 bolt to a 360? https://slantsix.org/forum/viewtopic.php?t=64842 |
Page 1 of 2 |
| Author: | Roneynd [ Sun May 03, 2020 8:57 am ] |
| Post subject: | Will slant six 904 bolt to a 360? |
Just got a '74 Duster with the slant six / A-904 automatic. If I swap in a rebuilt 360, will the transmission bolt up, or will I need to find a different one for the V8? Thanks. |
| Author: | Badvert65 [ Sun May 03, 2020 9:05 am ] |
| Post subject: | Re: Will slant six 904 bolt to a 360? |
No. Mopar small block, big block, and slants each have unique bell housing bolt patterns. |
| Author: | Joshie225 [ Sun May 03, 2020 9:25 am ] |
Sure! You just have to take out cylinders 5&7 to clear the starter. |
| Author: | GTS225 [ Sun May 03, 2020 6:49 pm ] |
You will also need a 360 specific torque converter. The 360 is externally balanced by weights on the converter, while the 318 and 340 is internally balanced Roger |
| Author: | plymouthcranbrook [ Sun May 03, 2020 9:01 pm ] |
And just wondering will the slant six 904 handle the extra toque and HP of the 360? As well as the rear end? |
| Author: | Reed [ Sun May 03, 2020 9:13 pm ] |
Quote: And just wondering will the slant six 904 handle the extra toque and HP of the 360? As well as the rear end?
This is a moot point because the slant six 904 will not bolt to the 360. You will need to get a small block 904. The small block 904s have stronger internal components than the slant six 904s.
| Author: | plymouthcranbrook [ Mon May 04, 2020 8:16 pm ] |
Quote: Quote: And just wondering will the slant six 904 handle the extra toque and HP of the 360? As well as the rear end?
This is a moot point because the slant six 904 will not bolt to the 360. You will need to get a small block 904. The small block 904s have stronger internal components than the slant six 904s. |
| Author: | volaredon [ Tue May 05, 2020 6:11 am ] |
HAHAHA HAHAHA |
| Author: | slantzilla [ Tue May 05, 2020 9:33 am ] |
I have a 904 behind a 340. The guts were out of one of my Slant race trans. Those guts were out of a small block 904. |
| Author: | Reed [ Tue May 05, 2020 9:43 am ] |
Quote: The small block 904s have stronger internal components than the slant six 904s.
I should have been clearer: "IN STOCK FORM the small block 904s have stronger internal components than the slant six 904s."
| Author: | jcc [ Wed May 06, 2020 7:17 am ] |
Your point was clear, and now its even clearer. |
| Author: | Killer6 [ Fri May 08, 2020 1:42 pm ] |
Won't fit, won't handle it, and that goes for both,...........
| Author: | kesteb [ Fri May 08, 2020 10:48 pm ] |
Does your car have disk brakes or drum? What rearend does it have? What size radiator? Do you have a V8 k-member? |
| Author: | NEVjr [ Thu May 21, 2020 5:59 pm ] |
Quote: Does your car have disk brakes or drum? What rearend does it have? What size radiator? Do you have a V8 k-member?
looking at a V8 and Slant 6 crossmember from a 64 valiant last year, I couldnt see any differences. the slant mounts would bolt right into the v8 crossmember but for the slightest misalignment. is there a difference? is only some years?
| Author: | slantzilla [ Thu May 21, 2020 6:14 pm ] |
Quote: Quote: Does your car have disk brakes or drum? What rearend does it have? What size radiator? Do you have a V8 k-member?
looking at a V8 and Slant 6 crossmember from a 64 valiant last year, I couldnt see any differences. the slant mounts would bolt right into the v8 crossmember but for the slightest misalignment. is there a difference? is only some years? |
| Page 1 of 2 | All times are UTC-08:00 |
