| Which Gasket manufacturer to use https://slantsix.org/forum/viewtopic.php?t=64852 |
| Author: | wjajr [ Tue May 05, 2020 1:59 pm ] |
| Post subject: | Which Gasket manufacturer to use |
Rock Auto has three listings for oil pan gasket sets, Fel-Pro, Mahle, and currently out of stock Victor Reinz. Which would be preferred manufacturer? |
| Author: | emsvitil [ Tue May 05, 2020 3:23 pm ] |
| Post subject: | Re: Which Gasket manufacturer to use |
Probably doesn't matter for an oil pan gasket. Cost difference? (shipping included) What else do you need? How can you get them to ship from one location? |
| Author: | DusterIdiot [ Tue May 05, 2020 4:32 pm ] |
Victor Reinz was bought by Mahle and was folded under that brand years ago...Both Mahle and Felpro gaskets are about par with each other for the timing cover and oil pan gasket pieces FYI... |
| Author: | Dart270 [ Tue May 05, 2020 5:28 pm ] |
Yep. Careful installation and use of sealer is the key. Lou |
| Author: | Greg Ondayko [ Tue May 05, 2020 7:07 pm ] |
Get the fel pro. For that pesky corner leak use some gasket shellac in addition to the above mentioned info as well as checking the articles section that Doc has a write up on sealing. http://www.slantsix.org/articles/gasket ... n-seal.htm Greg |
