| 1979 Slant 6 Valve Adjustment https://slantsix.org/forum/viewtopic.php?t=64857 |
| Author: | oldwood [ Thu May 07, 2020 12:29 pm ] |
| Post subject: | 1979 Slant 6 Valve Adjustment |
So the '79 /6 Super 6 are to be adjusted like the older /6's??? Am I correct in this assumption. .010 I and .020 E while running. |
| Author: | Dart270 [ Thu May 07, 2020 1:03 pm ] |
| Post subject: | Re: 1979 Slant 6 Valve Adjustment |
Yep. If the rocker arms have adjusters, then you need to do the lash. They went to hydraulic (non-adjustable) in 1981. The only twist would be if someone swapped your motor over to a hydraulic cam and rocker assembly, but I doubt it. Lou |
| Author: | Badvert65 [ Sat May 09, 2020 5:42 am ] |
On my 79 Volare Wagon, I adjusted them hot, .010 intake, .020 exhaust. I adjusted them after the engine warmed up but not while it was running. That worked well for me. |
| Author: | oldwood [ Sat May 09, 2020 9:47 am ] |
I do mine by the manual. Running with SNOT FLYING. LOL |
| Author: | plymouthcranbrook [ Sun May 10, 2020 8:59 pm ] |
I have only done mile once at about 22,000 miles. Warm engine idling away, went OK just a little oil flying about. |
