| Distributor Shield https://slantsix.org/forum/viewtopic.php?t=64945 |
| Author: | J S Goldman [ Thu May 28, 2020 7:39 pm ] |
| Post subject: | Distributor Shield |
Any problems or down side to removing the shield by the dist and oil filter? |
| Author: | SlantSixDan [ Thu May 28, 2020 8:34 pm ] |
| Post subject: | Re: Distributor Shield |
It's there for a real good reason, to keep water and mud and other gunk from hitting the distributor. It weighs almost nothing. Why would you remove it? |
| Author: | kesteb [ Thu May 28, 2020 9:57 pm ] |
Because the crack between the bolt holes. If you remove it, drive slow thru deep puddles, or you will soak the distributor. |
| Author: | DusterIdiot [ Fri May 29, 2020 6:10 am ] |
| Post subject: | D |
D |
| Author: | J S Goldman [ Fri May 29, 2020 8:11 am ] |
thank you all !!! |
| Author: | Rick Covalt [ Sat May 30, 2020 4:51 pm ] |
I think the modern ignition systems have lessened the need for that shield. Not that I think they are a bad idea or anything. Because they aren't. I was just thinking about my truck. We drove back from a race in Bristol a couple of years ago in torrential rains for about 4-5 hours solid. Truck doesn't have a shield and never made a peep! I know I coudln't have done that with a points car! |
| Author: | Jase [ Sat May 30, 2020 5:43 pm ] |
Quote: Truck doesn't have a shield and never made a peep! I know I coudln't have done that with a points car!
Anyone got a picture of one? I've never seen one and did not know such a thing exists. Both of my trucks are missing the shield as well, and I would like to make one.
| Author: | DusterIdiot [ Sat May 30, 2020 10:08 pm ] |
| Post subject: | D |
d |
| Author: | Jase [ Sun May 31, 2020 5:10 am ] |
Quote: Quote: Anyone got a picture of one? I've never seen one and did not know such a thing exists.
The first picture in this article:http://www.slantsix.org/articles/Distri ... %20IIa.htm Shows the shield on the left side of the picture in relation to the distributor, it is held by 2 bolts mounting the oil pump. Thanks DI. I can create something like that. |
| Author: | Doctor Dodge [ Sun May 31, 2020 2:10 pm ] |
I have a few spare shields that could be mailed-out, if needed. Send me a PM if interested. DD |
