| Weber 32/36 or 38? https://slantsix.org/forum/viewtopic.php?t=65015 |
| Author: | briwill [ Wed Jun 17, 2020 11:03 am ] |
| Post subject: | Weber 32/36 or 38? |
I'm in the process of rebuilding my six. Shaving the head and hoping for about 8.5-9:1 compression. Using an Oregon 2106 cam and electronic ignition. I have a super six 2 barrel intake and I ordered a Weber 32/36 to top it off. I'm reading some posts that the 32/36 will not be enough. Should I go with the 38 DGES? |
| Author: | Joshie225 [ Wed Jun 17, 2020 11:31 am ] |
| Post subject: | Re: Weber 32/36 or 38? |
You can run either, but they behave a bit differently. If you prioritize fuel economy then I would use the progressive 32/36. If you want sharper initial acceleration use the 38. http://www.redlineweber.com/html/applic ... ice_32.htm |
| Author: | briwill [ Wed Jun 17, 2020 11:51 am ] |
Quote: You can run either, but they behave a bit differently. If you prioritize fuel economy then I would use the progressive 32/36. If you want sharper initial acceleration use the 38.
Thanks again for the info! I have not seen that particular article before. http://www.redlineweber.com/html/applic ... ice_32.htm BTW: dropped off my block at Tabors for machine work yesterday!!! |
