| neutral switch wire missing https://slantsix.org/forum/viewtopic.php?t=65034 |
| Author: | grouchyandugly [ Mon Jun 22, 2020 1:09 pm ] |
| Post subject: | neutral switch wire missing |
1966 valiant S/6, AT just got this Friday. starts in any dumb dirtyword gear. single wire Neutral Safety Switch .. but no wire, anywhere I can see. tracked wire from starter relay (brown) to another relay, which was "2 into 1" relay. ??? is that NSS wire (brown) supposed to go directly to the NSS (one wire terminal) from the starter relay?? or ?? I ran a wire from the brown wire at the relay to the safety switch.... still starts in gear. any ideas/suggestions?? but THEN I had no "oil pressure" light come on. wheeeee. stay safe |
| Author: | hyper_pak [ Mon Jun 22, 2020 7:17 pm ] |
| Post subject: | Re: neutral switch wire missing |
There are starter relay units for manual and auto trans cars. There should be a terminal in the upper left corner that goes to the NSS. Dark Brown on my 62 Lancer. |
