| Cam and lifter match https://slantsix.org/forum/viewtopic.php?t=65048 |
| Author: | Bob_A [ Sat Jun 27, 2020 9:49 am ] |
| Post subject: | Cam and lifter match |
If I have both a brand new cam, and brand new lifters, does it matter if they’re the same manufacturer? |
| Author: | Doctor Dodge [ Sat Jun 27, 2020 10:04 am ] |
| Post subject: | Re: Cam and lifter match |
No, these parts can be (and often are) supplied from different manufacturers. It is more important that the parts are from a high quality manufacturer. Most SL6 camshaft "blanks" are still made in the USA so material and workmanship is pretty good. "Made-in-China" lifters are getting more common and can be suspect. DD |
| Author: | Bob_A [ Sat Jun 27, 2020 10:24 am ] |
What I have are Melling lifters, and looking at a Comp Cams .220/.220 |
| Author: | Joshie225 [ Sat Jun 27, 2020 11:23 am ] |
Why use an optimal-for-nothing camshaft from Comp Cams when, for less money, you can get something better for your combination from Oregon Cam Grinding or others? |
| Author: | DadTruck [ Sat Jun 27, 2020 1:05 pm ] |
consider Hughes Engines, http://www.hughesengines.com/Index/index.php when I spoke with them at the ICH Swap Meet they said they have many original Mopar cam profiles that are designed to take advantage of the large diameter Mopar lifer. The story was they have additional grinds available beyond the slant six cams shown on their web page. |
