| After ballast bypass still getting lower voltage https://slantsix.org/forum/viewtopic.php?t=65121 |
| Author: | bobbyturbopants [ Thu Jul 16, 2020 12:36 pm ] |
| Post subject: | After ballast bypass still getting lower voltage |
Slowly doing the hei upgrade, was wondering why the postive lead to coil is still lower than than battery? Small fuse ?crappy switch? Still should be enough to trigger a relay but why almost a volt Lower? And on a 72 valiant do I need to do anything to the charging circuit? |
| Author: | Badvert65 [ Thu Jul 16, 2020 1:36 pm ] |
| Post subject: | Re: After ballast bypass still getting lower voltage |
Likely either a drop at the bulkhead connector or the ignition switch. |
