| Oil Pressure Tap? https://slantsix.org/forum/viewtopic.php?t=65177 |
| Author: | ScrooLoose [ Sat Aug 01, 2020 6:46 pm ] |
| Post subject: | Oil Pressure Tap? |
Hello All. I would like to install a true oil pressure gauge on my 62 sweptline pickup with a 225. I have the low pressure indictaor light in the dash. But would also like to have a true gauge to see exact readings. Is there a second tap into a oil galley to install a fitting for this. Or is there another way you would achieve this. I would like to keep the factory indicator light and just have a 2nd gauge. Thanx. Jim C. |
| Author: | Joshie225 [ Sat Aug 01, 2020 7:26 pm ] |
| Post subject: | Re: Oil Pressure Tap? |
| Author: | Doctor Dodge [ Sun Aug 02, 2020 10:55 am ] |
Or check to see if the rear oil gallery boss is drilled & tapped. DD
