It is currently Sun Nov 15, 2026 1:19 pm
PostPosted: Mon Aug 11, 2003 2:24 pm
posting seems to be hunky-dory now. Thnx admin!
New dist. cap,#3 still dead(& #4 seems to be a bit slouchy) Gonna install new intake gasket next. Hear rumor that intake gaskets can be a problem on these engines. Waddya think(since th writin' on th' manifold says no more than 10ft lbs)?
Jim
PostPosted: Mon Aug 11, 2003 3:30 pm
Just how are you coming to the conclusion that its a dead cylinder?
If you think the intake/exhaust gasket is leaking, spray some carb cleaner in there and see if it makes any difference.
PostPosted: Mon Aug 11, 2003 3:58 pm
Try a new spark plug in #3 and see if that helps. They may look good, but they can be/go bad.
Users browsing this forum: DuckDuckGo [Bot] and 2 guests
