It is currently Sat Nov 07, 2026 11:54 pm
PostPosted: Sat Aug 08, 2020 2:01 pm
Car Model: D150
Newbie here but been lurking a long time. Can someone tell me the purpose of the hole in the intake. It is directly below the carb, a one bbl holley. Is it connected somehow to the egr, and do I need to plug it if I use an egr block off plate?
PostPosted: Sat Aug 08, 2020 4:49 pm
Yes.
No.
PostPosted: Sat Aug 08, 2020 9:57 pm
Car Model: D150
Thank you. So I don’t need to fill that hole. Thought I read a post somewhere that said it needed to be closed off if egr was removed and a block off plate installed. Maybe I just misread or misunderstood.
PostPosted: Sun Aug 09, 2020 7:35 am
Car Model: '23 T-bucket
Some folks have been known to tap that hole for a pipe plug. I think the worry is that with a block off plate, if you don't get it sealed around the EGR intake port, you could have a lean condition. With the pipe plug in the bottom of the plenum, there's no worry about that. Cut yourself a gasket for your plate, bolt it on, and go.
Roger
PostPosted: Tue Aug 11, 2020 11:14 am
I tapped that hole for the power brake booster, but all you really need to do to disable the EGR is flip it around 180 degrees.
PostPosted: Sat Aug 15, 2020 3:46 pm
Roger
I did tap the hole below the carb on my super 6 manifold, but when I got in there I discovered that there were already 3/8 NPT threads under the diamond hard carbon buildup that filled in the threads. I had to Dremel out some of that carbon to give the tap a place to dig in and start.
I used plenty of red loctite on the plug that I used. And I'm still gonna put a block off plate on the edge of the manifold.
Users browsing this forum: Google [Bot] and 8 guests
